Enrique schrieb:
By the way, I was living many years in Scandinavia, Denmark and Iceland, but I never had problems of this kind. Of course, at that time there was no digital camera, it was the era of the analog camera.
Gerhard57 schrieb:
Für meinen Tip will ich ein extra Foto haben!
GRUBERND schrieb:
i don't understand the difference between the "before" and "after" pictures. before what? after what? what happened inbetween?
anyway..
one thing that might happen is that the cold is changing the focus calibration. a camera with live-view is your friend. uses even more battery, but what you see is what you get.
going from warm into the cold is usually not much of a problem, i never had issues with that. and while the electronics and batteries might not be happy about the temperature, there is no such thing as freezing the sensor. astro-cameras cool their sensor extra low, so they get less noise. otherwise projects like "Chasing Ice" would never have worked.
but. going from cold into warm is the killer for the camera, because the warm air can contain much more water which will condense on any cold surface. try it with (sun)glasses. same effect.
so as others have said, take out the memory card, put the camera and ALL lenses into ziplock bags, then let them warm up to the conditions in the room before opening the bag. depending on the difference this might take up to two or three hours. you can always go back outside before and continue shooting. pro-tip: if you do indoor and outdoor shooting, you want two different cameras and lenses.
by the way, cameras using film have the exact same problem. even worse, the condensing water will get into the gelatine of the film, which can stick it together. on the other side film becomes brittle in really cold conditions, motor drives are "forbidden" as they put way too much stress on the film.
so stick with digital and be happy that you can shoot night time exposures in the multi-minute range without any thermal noise coming from the sensor. you just need a lot of batteries - or an battery-slot adapter and extension cable with the battery pack in the jacket.
enjoy the winter. =)
PS: do not charge any batteries below 0°C ... you will kill them if the charger does not compensate for the low temperature.
morgenrot schrieb:
.. that's right, nonetheless you'll probably take less problems using a crude mechanical tool over an extreme cold period.GRUBERND schrieb:
GRUBERND schrieb:
cold winters in the mountains
peterbild schrieb:
Roland Amundsen konnte 1911 am Südpol mit seiner Analogen Kamera Reisebilder machen ! Vermutlich war es eine Plattenkamera LG. Peter
Nikon F3 schrieb:
Ich würde mir eine Nikon F3 oder eine F2 mitnehmen. Die F3 wurde in der Jordanischen Wüste getestet. Sollte auch gegenteilig Funktionieren.
Dieser Beitrag wurde bereits 1 mal editiert, zuletzt von xx1 ()
Photo-Sorko schrieb:
And I'm curious: how cold is "cold" in Greenland?
